- Joined
- 11 Jan 2004
- Messages
- 46,709
- Reaction score
- 3,927
- Country
Crazy or not, it happens all the time. I have come across it many times. That is my point. It has never stopped anyone doing what you describe, connection or no connection.
I don't think that's true. The point of requiring an (electrical connection) is that simply plastering over it would entail plastering over live conductors - and, although there are undoubtedly some people crazy enough to do that (and we can do nothing about them!), most people are sufficiently non-crazy to realise that it would not be safe to do it.Crazy or not, it happens all the time. I have come across it many times. That is my point. It has never stopped anyone doing what you describe, connection or no connection.
Fair enough - but I still believe that that requiring a cable to be (electrically) 'connected' within a back box in order for it to create a safe zone will appreciably reduce the number of such incidents - since I really can't believe that the 'craziest of the crazy' represent the majority!All I can say is that, based on the number of times I have seen live cabling terminated in some form of connectors then buried in the wall, there are a heck of a lot of "the craziest of the crazy" around.
True but balance that small effect with the small effect in another context of unnecessary connections! Who knows which it should berequiring that (electrical) connection (for the creation of a safe zone) cannot do any harm in that context, and will sometimes do good.
Yes, I was expecting that one, which is why I added the bit about context!True but balance that small effect with the small effect in another context of unnecessary connections! Who knows which it should be
That's the ideal, but in the absence of an explicit definition, I think one has to consider context and apply common sense.If words used in the regulations have a specific meaning, then they should be defined in the regs.
Indeed - as I and others here so often say, there are countless examples in BS7671 of things that are less clear than they should be as a result of the absence of an explicit definition within the Standard. If they wanted to address that, they could do worse than starting with a definition of "non-combustible"!As I said, the IEE saw the need to explicitly describe a houseboat in the regulations, a word that does not leave much room for confusion, yet chooses to leave other words undefined.
You may now be talking more generally, but I have been commenting on the particularly reg under discussion and, in that context (and in the absence of a specific definition), I still really don't think that anyone with any sense (and, particularly, anyone contemplating doing work on electrical cables) would even dream that, in relation to an electrical cable', "connected" meant anything other than 'electrically connected'.I'm not just talking about this particular reg here, but all those that are ill-written or vague.
How does that number compare to the number of times you have seen cables terminated in some form of connectors and not buried in the wall?All I can say is that, based on the number of times I have seen live cabling terminated in some form of connectors then buried in the wall, there are a heck of a lot of "the craziest of the crazy" around.
Do you think that means that there are more bad installations than good?I have been to more bad installations than good
Have I got this right - that you really believe that there are more 'bad' domestic electrical installations than 'good' ones? If so, I wonder what other electricians here feel about that?In domestic premises, that's my experience.
