I know, but that's for reasons other than providing two current paths.607-02-05 calls for the ends of the protective conductors to be terminated in separate terminals.
So do lots of people, and that may well be what the IEE intended.The actual CPC within the ring is one conductor, however in the spirit of the regulation I take it to mean that there are two independant connections from the exposed conductive part (socket front) to the MET.
607-02-05 calls for the ends of the protective conductors to be terminated in separate terminals.I know, but that's for reasons other than providing two current paths.
BAS You told me you understood this subject - obviously not.
But unfortunately they got inarticulate fools who couldn't count to two to write the regulations.
Oh - so if you don't connect the conductors in a ring to separate terminals you don't get two current paths?BAS You told me you understood this subject - obviously not.
So how would you describe a group of people who deliberately chose to write a regulation which does not describe what they actually want people to do?Fools - I see - is that your considered contribution to this debate?
News to me.
In what way are they inconsistent?BAS Now Writes:
News to me.
These statements appear to me to be inconsistent - maybe I am just one of those fools you like to refer to.
Are you able to explain how connecting the cpcs to different terminal holes in the same earth bar, or in the same socket, creates two current paths whereas connecting them into the same terminal does not?There is very good reason why two current paths are created. It underlies the basic principle of both the problem and what many engineers consider to be its preferred remedy.
I don't know. Maybe because they are inarticulate fools?Well if you look at my posts on this on this topic you will see that I described them as engineers.
Tell me, if they are "inarticulate fools" how is it that they chose to write the regulation in the way you describe?
A RFC doesn't consist of a single wire.Can you explain to me why when you look at this:
you see, and I quote, "two individual protective conductors"?
Is that one of those Super Conductors? put the electricity into it at manufacture and the current goes round and round forever?Here's a RFC:
