Hikvision CCTV camera anomaly
30 Mar 2015
I have a Hikvision NVR and 4 dome cameras that have been working fine until this morning.
On my mobile app, 1 of the camera never appears in the Live View. I have tried closing and opening the app - no effect.
I then tried the web UI from my laptop and noticed that a different camera wasn't showing on there when I selected to view all cameras simultaneously. Note that this not the camera that is failing on the mobile app. After setting the offending camera (on web UI) to sub stream, I can then view all 4 cameras via the website. This has not been required previously.
I can playback all cameras - including the problematic one on the web and the mobile app. It appears to be a view-only issue.
I have restarted the system and this hasn't helped either situation. My upload and download speeds are good and as they are on any other day.
Thanks in advance.
On the mobile app iVMS-4500, go to the camera selection (top RH button) and check that all cameras are ticked. If that doesn't work, remove the camera settings completely under the Devices setting and re-enter them.
