- Joined
- 30 Nov 2022
- Messages
- 5
- Reaction score
- 1
- Country
Evening
Hive seems to have been done to death in this forum. But I can’t seem to find a topic that will help with my install.
I have a Logic Combi ESP1 35
Dual zone controls
All wiring seems to go to an ESI esrtp6 double valve PSU
From what I can work out, I connect the wires heading out the ESI wiring box to the thermostats to my hive receivers instead. And because there’s 3 wires coming out of the ESI box to the thermostat, on my hive receiver I have to connect L to 1. But this is where my knowledge seems to end. For some reason, the wires coming out the ESI box don’t match up with the back of the thermostat, which is confusing me. I’ve tried looking up the wiring diagrams but I can’t quite work it out. I can’t work out why 0V goes to RH on the thermostat. I figured +V is live, 0V is neutral (blue sleeve on thermostat), and RH is the switch for the pump.
Do I run +V to L, 0V to N, and RH to 3 on the receiver, with a jumper between L and 1?
I’ve attached pictures to hopefully clear up what I’m on about.
Thanks for your help
Dual zone controls
