Hello
My Honda mower worked fine last year, put away in the garage for the winter but now failed to start this week. A small amount of fuel left in the tank over winter.
I drained the old fuel out and replaced with new stuff and replaced the spark plug. On the first pull the engine starts for 3 sec and then stops, it will now not start if I continue to pull the cord but will start again for the same 3 sec period if left for a couple of minutes.
I have stripped down the carb, cleaned and re-assembled. I have checked that when the throttle lever is pushed into the choke position the carb paddle shuts off. Can also confirm that fuel flows from the tank to the carb bowl.
Any suggestions on what my next step should be would be very much appreciated, my grass is up to my knees!
Best regards
Best regards
