    Dismiss Notice
Honeywell Galaxy 2-20 user reset rquired error
Discussion in 'Alarms, CCTV & Telephones' started by chrisnasah, 6 Jun 2012.
  1. chrisnasah
    chrisnasah
    3 Aug 2011
    42
    Thanks Received:
    Bute
    Country:
    Hi Guys,
    Hope someone can help, i had my alarm installed last year by someone and for some reason i am not able to contact them for help.
    Well i have shock sensors on my windows which is causing me issues.
    I was getting the room done i.e. plastered and being skimmed etc etc and it seems they must have done something which has caused an alarm saying tamper on that window. When i go to the event i am not able to clear it and it says user reset required. Not sure what i am supposed to do.
    Similar issue i had was when my smoke alarm was activated i had the same issue, at that time i managed to get hold of him and all he told me to do was open the smoke detector and close it, that cleared the alarm saying user reset required.
    How do i do something like this for a window shock sensors?
    Need help as i am not able to activater my alarm now.
  2. Sponsored Links
  3. oasistechnical
    oasistechnical
    26 Dec 2009
    681
    Thanks Received:
    118
    Hampshire
    Country:
    sorry to hee this but you are going to have to contact a firm that can do this repair for you.
    unless you think that you could tackle it yourself?
    make sure the firms you contact can work on Galaxy panels, as not all firms can (or want to)
    Oasis
  4. Europlex
    Europlex
    20 Nov 2007
    2,963
    Thanks Received:
    268
    Country:
    Happens all the time. I expect a cable has been 'nicked' by the plasterers trowel. - Good luck.
    Did it not show up when it happened? The event/noise would have had to have been cancelled at the panel.
    If that happened and the plasterer was/is aware, when the cause is proved, if it is what I have suggested, guess who is responsible for the bill (not you).
  5. 9651
    9651
    27 May 2011
    164
    Thanks Received:
    18
    Cheshire
    Country:
    Yeah, if you've tried your code, pressed (A)to view the event, then (esc), and it still says reset reset the fault is still usually present.
    You can view the zone through the user menu if your code has the right authority. To do this proceed as follows,
    Code XXXX (ent)
    Press (2) (1) then (ent)
    Now use the (A) key to find the zone. It should say closed. If it says tamper its time to call the pro's
    To exit the menu press (esc) until the banner or fault shows again.
  6. chrisnasah
    chrisnasah
    3 Aug 2011
    42
    Thanks Received:
    Bute
    Country:
    thanks for the tips, it seems some of the wires have come out from it, and because this idiots plastered on it i have got any more slack, although i managed to join another cable and connect to where i think it came out from but still same issue.
    there are 4 cables connected, one red i guess power at bottom one black which i believe is neg, and another one pink going to alarm.
    The blue cable has come off from the tamper so i joined another cable but still didnt work, not sure if the cable is broken somewhere. Although i know others r fine as when i tap on it red light comes on.
    if am joining the cable and connecting to tamper, do i need to do anything else to reset it, assuming cable is working now connected where it needs to be?
    If no then how do i remove that zone so atleast i get use my alarm minus that issue.
  7. Workers
    Workers
    2 Jun 2012
    157
    Thanks Received:
    13
    Bath
    Country:
    Did you refit the resistors in the same positions you found them in?
    Just a chance.
  8. Sponsored Links
  9. chrisnasah
    chrisnasah
    3 Aug 2011
    42
    Thanks Received:
    Bute
    Country:
    yep, i mean the resistors did not come off only the blue cable, i got a feeling it was probably pulled hard which might have had a break in cable somewhere.
  10. Workers
    Workers
    2 Jun 2012
    157
    Thanks Received:
    13
    Bath
    Country:
    Have you the Master code?
    You may have repaired the fault but cannot reset. So check that first. If not its time to dig out the cable and trace the fault. A cable tracker would assist here. As you could find the break before any damage to the wall.
    This would entail getting in someone who can work on the product, as mentioned above.
    Then if it id down to a cut try and get the plasterers to pay. They should be insured.
  11. chrisnasah
    chrisnasah
    3 Aug 2011
    42
    Thanks Received:
    Bute
    Country:
    finally got it working.
    yep i had the master code, seems like i didn't clear the fault.
    Although i connected the tamper wire i thought let me check another cable, the alarm cable and to my horror the cable just came out from the wall seems like it had broken inside, hate the bloody plasterers.
    As the cable run had 8 wires and 4 were used, out of 4 two were damaged. Out of the 4 unused cables i took two and joined some extension wires and used masking tape etc. I connected this up and went to the main galaxy box, followed where the two original cables were connected and replaced with the ones i was using now.
    All looks and works good and tested it fully too.
    Would there be an issue joining cables using masking tape? It will be impossible to run new set of cables from the main box to the sensor.
    Thanks all for the suggestions.
  12. Workers
    Workers
    2 Jun 2012
    157
    Thanks Received:
    13
    Bath
    Country:
    Correct insulation tape is the norm. Soldering the joints if possible also. Your lucky the panel is on user reset too.
    Anyway well done.
  13. chrisnasah
    chrisnasah
    3 Aug 2011
    42
    Thanks Received:
    Bute
    Country:
    sorry yeah meant insulation tape not masking :) got it wrong
    i am good with soldering so could do that but maybe will leave it for the time being as the cable slack is so less going into the wall that if i messed the soldering i would lose more wiring.
  14. Europlex
    Europlex
    20 Nov 2007
    2,963
    Thanks Received:
    268
    Country:
    NO.
    Solder & wrap with insulating tape, if you know how that is, there is a Knack with insulating tape.
    Solder is very important, if you don't the joints will oxidise and give problems.
    Do it right, do it once.
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
