Hi all,
I've just installed and powered up a Honeywell galaxy dimensions 96 panel, with two touch centers and a Mk7 keypad.
The programming menu seems a bit of a mess in the manual, certainly not as easy to understand and follow compared to my previous experience with scantronic 9751/2 and io-ex160's that I've worked with previously.
So is there an easy to understand menu system other then what's in the installer manual? I don't have access to RSS software but have galaxyguy's ethernet module attached. Currently no telephone line directly connected.
Alternatively does anyone and a quick guide for setting up for home use?
Also my understanding was that the panel can take two batteries, but I can't see anywhere to connect the second battery.
Also in a bit of a rush to get it setup before Xmas so ebee if it's not fully functional and setup, standard zone is active/not active and bell box rings when needed would be a good start.
