- Joined
- 22 Jun 2009
- Messages
- 54
- Reaction score
- 0
- Country
I have a Honeywell v4073a1039 3 port valve in my heating system and now the hot water and the central heating work intermittently, though banging the valve with my hand seems to bring it back to life, sometimes briefly sometimes until it switches off whereupon on starting again many hours later, it fails. Though now that does not seem to be working.
I am getting some strange gurgling noises too, seemingly from places other than the valve when it starts to function e.g. the top of hot water tank. It almost as though there is a blockage and when the
What worries me more, is that if I do move the manual lever to the open position, which I think is directly attached to the spindle of the valve mechanism, nothing seems to happen! The pipe going into the valve don't get hot, and pipes going to the central heating and the hot water do not get hot, and the boiler does not fire up. The pump is on and active throughout this and the pipes are throbbing, but I don't know how to tell if it is pumping water.
So the symptoms are
1) Left to its own devices with pump on and CH and HW on, nothing seems to be happening in terms of pipes near the valve getting hot
2) Sometimes if I bang the valve with my hand sometimes CH and HW start to work after some gurgling noises
3) Sometimes turning off the HW allows the CH to work, after some minor gurgling noises from the system
4) The manual lever of the valve offers no resistance with the power off and it does not return to the auto position when released, as it should. I have played with one of these valves in a shop and the resistance to movement is much greater and the valve does return to the auto position.
5) If I move the lever to manual open position, nothing happens, neither CH or HW pipes from valve become hot and boiler does not fire. Does this suggest that the valve mechanism is not opening?
6) The pipes exiting the boiler seem to be hot, and boiler fires up briefly when first switched on, but quickly switches itself off when presumably it has heated the water inside it. The pipes near the valve are all cold including the one from the boiler.
7) The pump is going all the time, trying to do something and the pipework is throbbing! But is it pumping water?
So I think the problems could be one of the following
1) The motor in the valve has failed ( but why doesn't the manual open cause flow and the boiler to fire up ? )
2) Some micro switches are required to work which have failed along with the motor, and they are required to work to indicate to boiler the valve has opened.
3) The valve mechanism is physically not allowing water to flow out of either outlet ( but surely this is impossible, one of the outlets HAS to be open as all the valve can do is to close one outlet ?)
4) The pump has failed, and is pretending to be working ( but then why does banging the valve cause everything to work sometimes ? )
5) I have some sort of blockage somewhere ( but why does banging on the valve sometimes work, or it used to )
And some questions
1) Is the manual lever directly connected to the spindle? If so if I move it to open position then water must flow and therefore the boiler should fire up as hot water leaves it.
2) Does water HAVE to flow into the CH or the HW system if the pump is working? If so, then one or other of the outlet pipes should be getting hot, but there are times when neither are getting hot and the boiler is not coming on, as though there is no water flow.
3) As I understand it there are some micro switches in the valve, if they are not operating correctly, does the boiler think that the valve has not opened and therefore does not fire up?
4) Should I just replace the motor in the valve, and see what that does?
5) What should I check on the valve? Should I be checking the micro switches
6) Should I be worried about the pump?
7) When the valve is working should the lever move over to the open position when it is doing HW or CH?
Thanks in advance for any analysis, hints, or information.
So the symptoms are
And some questions
