Recently moved to a house with oil heating system.
Everything operated fine.
I disconnected the oil supply to move the tank to do some construction work. (well the builder did)
When the supply was reconnected, my boiler would not fire up.
I have a Rellio RDB burner.
I pressed the red 'ignite' button around a dozen times to try and ignite the system but failed.
I read on the internet that the system needs bleeding by unscrewing the large hexagonal bolt which is underneath the red cover.
I removed this until I got a stream of oil and the burner ignited.
Since then, there is a very strong unbearable smell of fuel.
There is a dial on the side of the burner with a numbered dial.
This was set to number 3.
Thinking that the burner was running too rich, I tried reducing this to number 1 with an allen key but made no difference.
I therefore changed it to 5 and this also made no difference so put it back to the original setting of 3.
I don't know what to do next.
My next thought is to isolate the oil tank so as the burner runs out of oil and stalls again.
Then re-bleed without pressing the ignition system without pressing the red igniter button and perhaps 'flooding' the burner.
Any help or advice greatly appreciated.
