Hi all,
I'm new here and needs some advice. Here goes...the Hot Water system works fine but the Central Heating will not come on
The boiler is a Potterton Suprima 50, and the digital controller is a Potterton EP2002. I know problems with the Suprima boilers are well documented but I'm not sure this is the problem this time. Showing on the bolier is an Amber LED not the Red, so I suspect it is not 'lockout'. The info I have says this most likely 'no external call for heat'. When you run hot water for a while the LED goes green and the boiler fires up okay until the water is heated again.
I have checked the thermostat is switching okay and the is 240V present on both sides of the switch when moved.
The Red LEDs are both on on the EP2002 digital controller.
When the Hot Water is on and boiler running, the pump near the tank in the airing cupboard runs.
I measured the voltage at the boiler and on the Hot Water side there is 240V
I measure the voltage between the SwL and the terminal mark Pump and there is 38V
I suspect this could be the controller at fault? Any other ideas or places to check before buying replacement parts I may not need?
Please help........we're cold!!!
