fitted my first Hot water cylinder today,had a couple of leaks,i suspect some of the gaskets was missing,its been a long time since i did one at college,so can not remember where gaskets are used
first leak was on the connection where its sits on the tank on the pipe that feeds the hot water to the house,should there be a gasket between the nut and tank,i was
refitting the system the same way as i took it off,but now it leaks and i do beleive a gasket would of stopped this,or is it ok to use plumbers mate,
second leak was on the immersion heater,i used a new gasket,i do suspect that some plumbers mate may of got between it and not let it sit properly,plumbers mate was evident from previous person who fitted the old tank,when i was at college my tutor gave me a tip of wrapping ptfe round the gasket to help seal it better,any other tips,worth remembering,tomorrow i will give it a good clean with spirits
the cold feed to the tank,should there be a gasket fitted here when tighting the nut,im sure there should be one here,
does anyone have a broken down pic of a tank and its connections
thanks
thanks
