hi
we've had this machine for 3 years now and regularly clear out the fluff - However not for the last 10 months atleast
recently when the machine turns off or after 2-3 mins off operation the main fuse in our fuse board trips.
i cleaned out the filter and looked in the little tub at the back where the overflow seems to run and that was full of water so i emptied it.
however behind the filter at the bottom there is a lot of water and i can't see any obvious way to access that, i'm guessing that is causing possible shorts in the machines. i took a small panel off at the back and their was water in that, so the machine is currently laid flat down on the floor to try and drain it.
any further suggestions would be much appreciated as we cxld our extended warranty 1 year ago
