I was asked to have a look at the electrics in a house which a customer has just had an offer accepted on. The house is 38 years old.
When I got there the customer showed me the survey results. There wasn't much on the electrics but it did say:
- The consumer unit needed replacing.
- The sockets needing replacing (because they were unswitched)
- It would probably need a rewire.
- Cables in the boiler cupboard were clipped to the wall
The new owner wanted me to have a look and try and determine what work was required and how much it would cost as he was now going to try and get a reduction on the asking price. The problem was that as the contracts had not been exchanged the estate agent insisted on being there so I only had an hour to give it the once over.
The consumer unit definately needed replacing so this was easy enough, however :
Is there a requirement to change the sockets to unswitched? (ie would the new owner be able to use this as justification for reducing the price).
Also, who is to say that a rewire is necessary? obviously a full test would highlight any problems but even then, a rewire isn't necessarily the answer. I suggested to the new owner that as the property is nearly 40 years old it is probably due, and that now would be a good time, but he says he can't really afford it and if he asked the old owner to pay half, would the old owner have a case for saying that a rewire is not necessary.
I checked a sample of sockets and switches and everything looks ok, properly sleeved etc. The lights have an earth. Obvious mods (Whirlpool bath, pond pump) seem to be have done as correctly as possible with rcd's added, both bondings are there with correct size cable.
I think the guy was trying to get me to put in writing that a full re-wire is necessary so he could go back and get a reduction but I am a bit loathe to do this when there is no obvious evidence to back this up. The fact that there is a dearth of sockets and that they are unswitched is more of an improvement than a requirement isn't it?
