    Dismiss Notice
House way too hot
Discussion in 'General DIY' started by Rossy_87, 6 Aug 2020.
  1. Rossy_87
    Rossy_87
    25 May 2020
    2
    Thanks Received:
    Country:
    I live in a 1960's house, that is constantly way too hot throughout the summer - I know that this is expected during the warmer months, but it's way hotter than it should be (upstairs is ~29 degrees in the evening). I've tried various advice I've found online such as keeping blinds down, whilst allowing ventilation to flow through the windows, trying to push air around using a fan etc. We also got our cavity walls insulated last year, but nothing has really helped.
    There is some quite thick insulation on the floor of the loft (where it's also swelteringly hot) - is it possible that this is having an adverse affect? Would opening the loft hatch and trying to force some air circulation up there help things?
    Any tips would be appreciated. I'm open to spending a few hundred pounds to get this sorted, although not too keen on the idea of air con.
  2. Sponsored Links
  3. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,845
    Thanks Received:
    2,088
    Devon
    Country:
    Actually opening the loft hatch can be helpful and draw the air through the house ie leaving it open all day and night, give that a try. What you're experiencing is nothing unusual.
    • Like Like x 1
  4. JohnD
    JohnD
    15 Nov 2005
    66,195
    Thanks Received:
    3,589
    Coastal
    Country:
    Cook Islands
    Yes, I started doing that when I bought a house on the South Coast and only got to it at weekends. It keeps the house generally cooler, and if you open the front door on a sunny day, you will notice the updraught is very strong. The air rushes into the loft and pours out through the eaves, by simple heat convection.
    mine is open as I type this.
    A hooked pole, and a fanlight catch, enables you to open or close it without needing a stepladder.
    [​IMG]
    https://www.ironmongerydirect.co.uk/search?query=fanlight catch
Loading...
Share This Page
