Hi all,
Sorry for this newbie question but I've been searching for help on this for a quite a while and just thought it would be easier to join and post a question.
I moved into a end of terrace house 2 years ago and the 1st winter here was absolutley freezing. The following spring I had cavity wall insulation and loft insulation done which made it a lot warmer the following winter. However I now get mould growth in most rooms. What can I do about this?
Some advice I've received is to put air bricks into most of the rooms but only go from the inner wall into the cavity and not all the way through the outer wall as it'll make the house cold. Does this sound right? Will this help?
I've also been advised to leave a small window open all the time but obviously this isn't ideal security wise and don't want to lose heat from the house in winter.
I'm trying to be proactive and get ready for this winter as the mould has ruined some of the wallpaper and plaster that I had decorated when I first moved in. I've tried treating it last winter but it just seems to keep on coming back!
Any help/advice would be most appreciated.
Steve
Steve
