How do I form a seal between these please
30 Mar 2015
I've installed an in-line extractor fan (brilliant idea that came from this forum) for my bathroom extraction. It has the white duct which then connects to a solid pipe (this was there previously).
I've just noticed that there is a water drip where these pipes join. I slipped the white duct over the solid pipe and then wrapped some duck tape over it.
The lighting isn't great in my loft but I've attached a few pictures.
How do I achieve a water tight seal please.
Thanks in advance
You could try self amalgamating tape must be stretched when applying.
Are both pipes designed for extractor if so the supplier should stock some kind of adaptor.
Thanks for the response.
I am unsure on the solid pipe as it was previously there. I think this was the vent for a toilet once upon a time.
Have a look in the catalogs...Manrose etc. You can get adapters to pvc that allow you to "screw in" the flexible pipe. I guess Screwfix or Electrical wholesallers etc will do them.
I purchased the flexible ducting from screwfix but can’t see that they do a reducer/fitting for my situation. I am assuming that my solid pipe is 110mm.
I can cut the solid pipe higher up so the joint isn’t at the lowest point.
I can’t use a solid pipe throughout as the ducting is passing from one side of the loft to another. In between, is my boarded area (walkway in the loft). The flexible ducting goes up and then down the rafter you get to the other side of the loft. I hope this is explanation makes sense.
I appreciate your help in getting this solved.
I spoke to a local specialist today and he suggested using the flexible rubber connectors. He did suggest that the sizes wont be perfect. I assume that one end will tighten on to the 110mm pipe and the other end will allow me to slip the flexible duct over it. Similar to what @Ian H posted earlier I assume.
I can also cut the solid pipe further up so that the join is not nearer the lowest point. Does this sound plausible?
Good Morning All,
Can someone please help me with clarifying the above? I am very keen to solve this before I start to get the water seeping through my bedroom ceiling.
Thanks in advance.
You need to make a proper seal where the flexi connects over the hard plastic pipe - Best way to do that would be with the bespoke connectors linked to previously or alternatively large jubilee clips. Wrap the end of the plastic pipe in several layers of duct tape to take up a bit of the gap, then push the flexi pipe over it and tighten the jubilee clip down. The tape will give a softer area for the clip and pipe to seal down onto.
Those rubber flexiseals won't work with the flexi pipe, better suited for the hard pipe. There would need to be a hard liner in the flexi for then to grip to and then you are back to the same situation
Just be careful not to pierce the flexi pipe as that would just defeat the purpose. As suggested though that condensation from a bathroom extractor is common in these situations especially with longer runs and where the air velocity can be reduced, so you may have to find someway to cater for it.
