I just bought a ridge hook kit to bolt on to a ladder so I can get up to the chimney safely, however I only have a 2-section and 3-section extenison ladder.
The latching mechanism on an extension ladder is clearly designed to stop the ladder shortening when weight is applied to the top, but when its hung from a ridge the weight will be trying to extend the ladder.
The videos and instructions I've seen are only for single section ladders.
Would I be correct in believing that:
1) you cannot prevent an extsnsion ladder from extending?
2) I need to bolt the ridge hook to the bottom section of the ladder?
3) I can rely on the bottom stop from preventing the top section from going below the bottom section, and so it should be safe to climb the ladder in its non-extended state treading on the upper section?
or do I need to seperate the sections of the ladder and use it as a single section ladder as that's all the instructions are written for?
