How do you measure a radiator ?
13 Feb 2006
Tyne and Wear
How do you measure a radiator, ready to change it to a new double one ?
Last year I decided to change a towel rail so measured centre of pipe to centre of pipe thinking this was correct. The plumber had actually said it's a 600mm rail, but as he hadn't actually measured it, I assumed he was wrong. He returned about a week later to carry out several jobs, but when he came to fitting the towel rail there was a problem. Luckily I managed to take it back and buy the 600mm one, which I should have bought in the first place.
Now we want to replace an existing single radiator with a double and it'll be fitted by the same plumber so I don't want to make the same mistake again. He thought I was a chump then, so not sure I want to be a bigger chump now.
With a tape measure :p
Sizes are typically height first - top or bottom end to end - not the centre
Towel rads are alway outside edge to outside edge, pipe centres are a supplementary measurement.
