Dear all,
Can someone explain to me how gas hob ignition work. Our whirlpool gas hob ignition stopped working, I switch the main switch off on the right hand side of the hob off (it has 3 am fuse, and written on it HOB) lifted up the ignition from the side of the hob, and disconnected from a little transparent plastic box where two wires are connected, both are the same colure black and white. I then switch the switched on and tested both wires, I was expecting that one of the wire would be live, and when the ignition is pressed the centricity then flows to the other wirer to the ring., but not of them is live.
I am right in assuming this?
