How many downlights to use?
30 Aug 2006
London
How many dimmable 50w downlights would you all recommend for a room of 17ft by 11ft? The ceilings are 8ft high.
I think 9 (3 x 3) but have been advised that 6 ( 3 x 2) would be more than sufficient.
Also, the ceiling is 12.5mm plasterboard with a skimmed finished so would 60 minute fire & acoustic rated lights be acceptable to the authorities?
bog standard fittings would probably acceptable, depending on whether theres a flat or a garage above.
Whatever number of lights you choose, if you're dimming them, splitting them into 2 or 3 switches will prove beneficial to your dimmers.
It's on the top floor so above me is just a flat roof.
The room is an open plan kitchen/ living room so I was going to split it into two areas for lighting; the kitchen with 3 lights and the living room with 6. Each area will have its own dimmer switch.
i thought the general recomendation on here was a total of 0 downlights.
jwilliams said:
Garage above? :shock:
You never know! :lol: I was hypothetically speaking. Were there a garage above, the ceiling would have to be fire rated (IIRC), since all barriers between garages and living accomodation must be fire rated!
i've seen a transit drive through a door and straight into a lift once in the center of manchester somewhere presumablly to be unloaded on an upper floor.
It wasn't a window-cleaners lift was it? like on the adverts? :lol:
it just looked like a fairly ordinary (metal box with buttons in it) but rather large lift though i didn't get a very good look at it.
