How to accurately mark behind wet wall panel
1 Apr 2013
Norwich
Basically I'm putting wet wall panels up in the bathroom and was wondering if there is a nifty trick to accurately measure and locate plug holes and switches etc
Offer up panel to wall and level a line across to top and bottom of your socket, reduce measurement 5mm top and bottom to allow overlap of socket edge .
Measure across to socket from previous panel or corner of room to either side of socket ( reducing again by 5mm for overlap).
If your measuring skills are poor increase overlap to 10mm and adjust after testing fit .
(You can always make aperture larger to fit).
Pencil marks are easily wiped off.
If you have a laser level, you can point that at the spot on the wall and then mark where the laser meets the ceiling and adjacent wall.
Draw a line of blue/red chalk, or red lipstick*, over the edge of each socket/fixture. Place your panel level to the floor and gentry press the panel against the sockets/fixture to transfer their location.
*Black lipstick if you're goth.
If you have a laser level you can put it + mode, align the cross on one corner of the socket etc then place the panel in place and mark it up where the cross shines on it
Tried that and it works great.
Really interested in buying a laser level. I'm just an enthusiastic beginner but really enjoy this DIY stuff. Please suggest a laser level that'll be good for my low skill level. Thanks.
There are various brands of small cube-shaped lasers that cost about £50. Example: I have a Bosch Quigo. Then the prices jump substantially. I guess the more expensive ones are better, but I've never used one.
I have the Magnasson Green one from Screwfix, pretty sure I bought it on special offer for about £30 if you don't need one straight away and are prepared to wait.
