I built shelve with LEDs. I'd be grateful for advice on how to connect them safely/correctly.
One of the top shelf wires is the mains supply that is run from a light switch which will be connected to the driver AC in. The driver DC end will be connected to the to shelf LED and to the the second wire that is chased into the wall onto the middle shelf. that is connected to the middle shelf LED and paired with a wire that is going to the bottom shelf LED in a series circuit. see below a diagram that Gemini drew from my description.
What is the correct way to connect the DC wires pairs, and what wire connectors would you recommend? Is it okay to place the connected DC wires in a cavity inside the wooden shelves?
TIA
TIA
