How to connect these strip lights
14 Jul 2014
Yorkshire
Looking for a warm white LED strip to fit under my kitchen cabinets. Ideally, I would like one with a remote control - although do not want the RGB coloured LED's, just warm white.
Seen these on Amazon - click here
I would need to cut a strip for each side of the hob. How would I reconnect these, would it be a case of soldering some wire between the two? What gauge wire?
Thanks in advance.
I have found the wire on eBay, here
Is this just normal speaker wire?
It's just wire - you can use pretty much anything which will carry the current the strips will take.
BTW - have you thought about how you'd solder this to an LED strip?
