how to fix timber studwork to block base
19 Dec 2007
Warwickshire
Thought I would make my subject a bit clearer!
I am building a garden room and plan to use a concrete block base with a wooden structure over - a sort of seaside chalet if you like!
How do I best attach the timbers to the blockwork base? Do I just use wall straps?
I plan to build a studwork frame and then line each side with ply and then weatherboard the outside. What type of ply is best - does it have to be the marine sort or will flooring grade do? Would t and g be ok or would it move? I will insulate also but where in the sandwich making up the wall does a moisture barrier go?
Also when I do the floor do I need two damp proof layers - I saw our builder when he did our new garage put plastic down then hardcore then concrete.
Would I be able to use roofing slates to finish it off or would there be a weight issue over time - am I better off with felt.
I am sure there will be more questions but thats it for now. Many thanks.
i'm not sure whether you are building a glorified shed or a mini-extension.
if you are using dense concrete blocks for the base then i guess you could screw-fix a 75 x 50mm tanalised wall plate to the blocks, from which to start the walls.
use a polythene vapour barrier on the inside of the stud and a sarking or breathable felt on the outside.
