- Joined
- 27 Feb 2024
- Messages
- 8
- Reaction score
- 1
- Country
I am intending to move house later this year and was intending to buy a house that needs renovating and has space to extend. I intend to remove any gas supply for various reasons including the gradual move away from gas and the fact that although I cannot generate my own gas, I can generate electricity. This decision has already been made but I am trying to figure out how I could best heat the house using electric and would welcome any suggestions so I can start investigating in advance. I would intend on also having battery storage in the house charged either by solar/wind or taking use of cheaper rates at various times of the day to offset the house usage. I also do realise using electric to heat the house is more expensive (currently) than gas but if generating some electricity and removing the gas standing charge etc entirely would partly offset this.
I would intend on insulating the house well and some rooms particularly bedrooms would only require minimal heating as they would gain heat from downstairs anyway (My current 1950s terrace has the heating turned off in all bedrooms as they stay warm enough from the house heating).
I looked into heating the downstairs using electric underfloor and naturally there are mixed opinions but I think in general it can be expensive to run and is best when used under tiles as opposed to other flooring types so I may consider this for example in the kitchen / dining area depending on flooring.
There is a push towards Air Source Heat Pumps which I am not over keen on as generally I would prefer not to have wet underfloor heating due to raised floor height and if possible removing the need for water pipes to heat every room is just a much cleaner look that I would be very keen on.
I have seen various electric radiators which are thinner than standard radiators which I wouldn't mind but any other suggestions of heating the house using electric would be welcome. I had considered a small separate unit for the bedrooms that could be used for both heat and cooling on warm summer nights etc may be sufficient upstairs.
Any suggestions would be welcomed as I'm sure there are technologies that I haven't heard of or are new that I could look into when planning. Thanks in advance for your time!
