how to insulate my vaulted ceiling
10 Nov 2015
hello,
my vaulted ceiling has no insulation, and it gets cold in that area of the house during winter.
it is an upstairs hallway vaulted ceiling.
a 1920s plaster and lathe ceiling with about 2inch (5cm) gap above, after which is positioned the slanted roof [a 1970s grey membrane/plastic is under the tiles].
to reduce the cold in the hallway,
i plan to put Kingspan Insulation Thermapitch TP10 2400mm x 1200mm x 25mm boards onto hallway side of the ceiling:
1. would i need a vapour paper/membrane etc to stop condensation
2. can i just fix it the kingspan onto the rafters thru the plaster ceiling, without using battens?
thanks
jon
