- Joined
- 18 May 2022
- Messages
- 4
- Reaction score
- 0
- Country
My roof was re-tiled last year and we had plastic Dry Verge Caps fitted. The top of the cap is screwed in to the timber batons and the lower end of the Dry Verge Cap is not secured (the bottom one is screwed onto the guttering too though).
Unfortunately 1 of the Dry Verge Caps blew off in the storms in Feb. My builder is going to fix it under warranty but I am wondering how to make sure he does it properly.
It looks to me like the only exposed screw is at the very Apex of the roof on the round cover piece and that every Dry Verge Cap lower down has the screw covered by the Dry Verge Cap above it.
Should he have scaffolding put up or a Cherry picker so he can safely remove all Dry Verge Caps from the top down then screw it back in properly or can he get away with sliding it in and using some sort of glue, is so what glue? I am worried about him just turning up and screwing that 1 piece in because that will be the only exposed screw. I'm also worried the end of the timber baton is now weak as the screw has been ripped out by the wind once already, does he need to screw in a new short piece of timber baton and get a nice new screw hole into that? That would mean removing at least the Dry Verge Cap above the missing one.
One other idea is that he could glue the dry verge cap onto a short length of timber baton and slide it then going into the loft secure the short piece of baton. This seems a bit cowboy but might save a whole scaffolding because I know he can't safely reach the apex without scaffolding.
Anyway I just wondered what the proper way to do it is.
