I'm having a problem with one of the MR16 halogen recessed downlighters in my bathroom. At first the light would occasionally go off and I simply needed to take the bulb out and put it back in again every now and again. Then it started to flicker and has now gone completely. It is not the bulb as I've tried a couple.
Reading about it, it seems it is quite common for the bulb connectors / holders to fail. I think this is the case with mine as it seems a little corroded.
I see you can buy them for less than a pound, but I'm not sure how I replace them? Looking into the recess I can see the wire which the bulb holder is connected to goes through a hole in what I would describe as an upside down can and then I assume it connects to a transformer?
I can probably access the top of the lights from the loft space.
Any advice much appreciated.
