How to use this expanding fixing?
Think the chippy recommended the expanding fixing because of the soft brick.
This is what happens to an umbrella fixing when properly installed into a hollow plasterboard wall and set using the setting tool:
You can readily see that the type of fixing you are using won't work at all well in solid blockwork because the "umbrella" can't readily open in the block material. The type of fixing below, the Fischer UX (designed for soft blockwork and plasterboard):
does work in the circumstances you are talking about. Is it possible there's been some confusion about which Fischer fixing was being referred to? See Fischer web site for details
Tried these as well. Hardcore screw.
Anyone know material am drilling into? View attachment 133688
This bolt/screw thing is really strong. Just put it in.
The other two were pulling out of hole or turning when I tried to do screw up. The plug is 10mm so hardcore
That's a 6mm thunderbolt. You don't use them with plugs.
Just drill a 6mm hole.
And are the best form of fixing into masonry.
Yeah, it's one of the longer ones. Is it supposed to go behind the back (2nd) plasterboard and expand behind it? I am using it in these brick sized white soft things which are more crumbly and normal red bricks and brown plugs don't get a great fixing - will send photo. They arent as hard as orange bricks. I used a shorter expanding fixing before in crumbly old plaster (in an old house) where the hole was big and it worked well,
Can you get thunderbolts out relatively easily when you want to take them out? Best to put them in and out with a rachet?
