Desperate for advice.
Have had this Ideal boiler for a long time. About 10 years ago, the gas valve was replaced. Last week, the boiler went off, but the pilot light stayed on. After speaking to a gas fitter, he confirmed my suspicions, the gas valve.
All electrics are ok, thermostat is ok too. I ordered a new Honeywell valve and fitted it. Started the pilot light and then switched the boiler on and to my delight, it fired up instantly. I was over ther moon, but then about 20 seconds later it went out. The pilot light was still on. I turned the thermostat, checked the timer, checked everything, but everything was ok. It was the same fault again with a brand new gas valve.
Is it likely that I have bought a dud even though it was apparently new?
Any advice would be very much appreciated. Its freezing without the heating.
