ideal icos 3080 - pcb fault, what's causing it to fail?
29 Nov 2007
Bristol
recently moved into a flat with the above boiler connected to an unvented hot water system. the system worked for a couple of weeks then nothing.
the code on the display said pcb needing replacing but it blew up too.......
£200 wasted.
I have checked resistance on the fan at 120ohms but the gas valve is 4000ohm, am I going mad or is it because there is no power on or is this the reason the pcb is blowing up.
any ideas please
30 Apr 2006
Durham
have you put the plugs in the right place theres 2 that look the same but dont go in the same place :evil:
23 Feb 2007
Norfolk
These pcbs are notorious for blowing without any other fault. Just c r a p Ideal design and reliability.
Fans though, are also extremely common for taking out things on these as well.
Other things to check would be pump and look for any leaks, ie auto air vent leaking.
29 Dec 2004
Bedfordshire
They also have a fault with the rear insulation panel falling down inside combustion chamber and the burner fires direct onto the ali casing causing it to burn hole in the rear of it. This then burns through the fan cable blowing pcb and fan.
23 Feb 2007
Norfolk
I agree with the above, but usually this causes it to burn through he and outer case at back. Fan loom is at front of he.
8 Dec 2007
I saw on another post someone discarghing hte capacitor on the pcb. maybe worth a last resort.
8 Sep 2005
worlds end
fan definatley causes pcb to fail, do ideal carry out a fixed price repair? a lot of manufacturers do
23 Feb 2007
Norfolk
Yes they do, but not at present as they are too busy with warranty work :eek: :rolleyes:
