Hi
I have a ideal icos he15 boiler
I turned all the valves off in the airing cupboard to the cylnder and rads and returns
I believe !
I changed all the rads as they were old and
Not economic
Now I opened all the valves again
Turned the boiler on
It does a set up goes to c
And burner fires up stays on
Then flashes and goes off
There is a little pressure in the rads
But just can't bleed them as not enough pressure and
The bolier goes off so no pressure
I've got water coming back
Through the hot taps but no pressure
And not hot as haven't got that far to
Check the hot water yet
Do I have to bleed something else first
Or do I increase pressure fom boiler
Somehow
It obviously not a combo system
As you can just increase the pressure
When bleeding
I'm really stuck
Can you help please
Thanks gary
I believe !
Not economic
Somehow
When bleeding
I'm really stuck
Can you help please
Thanks gary
