Ideal Isar - Programer
26 Sep 2007
London
Hi All,
Help!!!!
I have just made the grand mistake of buying and installing an Ideal Isar 24HE Condensing Combi Boiler. :cry:
I originally bought an independent a Honeywell programmer/ timer thing, however when my electrician went to fit it he said it was not compatible.
I am often out of the house for long periods of time an generally only need the heating for a couple of hours in the morning and the evening
Can anyone recommend a programmer/ timer?
D
Why is it supposedly incompatible? All the wiring on an Isar is at 230V and all you need is a switched live back to the terminal block to tell it to come on for ch.
I think your sparky is telling porkies unless you haven't told us the full story :?
I like the HE Isar, much better than the old m30100
not a bad boiler on a CLEAN system
Thats me all over
But the HE is a much better boiler now than it used to be and most of the issues of the old one have been sorted
I also Like ravenheats
After going to installer live I now like the Broags even more and the Halsteads because of the flexible flue liner option. (and my mate is their local repair agent if they go wrong 8) )
Only problem is I can't be seen buying a boiler from a shed :shock:
He said that the programmer has to be wired to a cylinder and my boiler did not have one
I would guess from that comment that its a twin channel one, in which case just use one channel.
He obviously hasn't a clue. Where did you find him?
