Hi All,
I've got an issue with my Ideal Mini C28, CH works absolutely fine but when I turn the HW tap on the DHW Flow switch clicks and the LED comes on but the boiler does not ignite, however if I take the diverter valve actuator off and manually push down the diverter valve (while the HW tap is running) the diaphragm pin extends and activates the CH flow switch and the boiler ignites and I have hot water.
Is this right? If so it sounds like the diverter valve is duff but because CH works I'm not sure.
Anyone have any idea what the issue might be?
Any help much appreciated.
Paul
Paul
