- Joined
- 27 Jan 2008
- Messages
- 28,080
- Reaction score
- 3,408
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It was tripped when I moved in, and resetting it, it tripped again so I as a temporary measure turned the temperature down, down in fact to 45ºC which is too low, the TS-220 15A 240 V~ was replaced, and the setting left as it was supplied, Tesla UK Part No 21275 which looks identical to old one, ran for around 3 weeks, then found the reset had tripped, powered from an iboost+ it was OK until I set it to boost overnight, using the off-peak.
I have always considered if the reset trips, then time to renew to be on the safe side, but so soon after fitting, I wonder what else can cause it to trip? Not inclined to swap a second time, but maybe reduce the temperature a little, but wonder if missing something.
