- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
The 2kW thing is GUIDANCE. It is not a regulation.An electrician may refuse to wire to a ring final, regulations advise over 2 kW should be a dedicated circuit. But it is permitted under some precautions.
How do you know? You haven’t told us anything about the characteristics of the circuit!. No way would the circuit be overloaded.
I purchased some 4 socket extention leads in Auchan Calais some 8-10 years ago, I struggled to find French style. In Croatia just slighty more recently it was all German/Italian/2,5A versions.Where did you get this gem from? Being in France recently I saw no evidence of such a change.
Yes it says one way to comply with 433.1.5 can generally be achieved by. A 13 amp load at the centre of a ring final is unlikely to cause a problem. Near the CU however it may. Using the loop impedance tester easy enough to work out how close to centre or ends of the circuit, but most DIY people don't have one. And it only really applies to ring finals.The 2kW thing is GUIDANCE. It is not a regulation.
Croatia uses Schuko sockets. Italian are different, 3 pins in line.I purchased some 4 socket extention leads in Auchan Calais some 8-10 years ago, I struggled to find French style. In Croatia just slighty more recently it was all German/Italian/2,5A versions.
2019 a friend travelled France & Germany for nearly 4 weeks and reckons he encountered a multitude of different versions in some of the 'out of the way' areas.
https://www.tlc-direct.co.uk/Products/SMFST77.html I have this, it's a fused spur so replaced the socket on the ring.
Of course - except the last socket.Or would a radial have two cables also?
