Hi im a small bit confused about finding the values of the loop impedance of an installation. I fully understand the path of the loop and all that but im stuck on the temperature factors to be applied.
If you use a loop impedance tester , is the value displayed the correct value or do you need to apply a temperature corection factor as the cable will most likely not be at its highest temperature capability i.e 70 degrees. Or does this method only apply when manually measuring the impedances
Sorry if i confused anyone
