The property I just moved into has a Salamander RIGHT RSP 100 which is rather noisy, I'm wondering if that's down to the installation. I saw a video on youtube of a similar pump and it was near silent, with ours it's in the airing cupboard and you can hear it through most of the house. It's dated 2006 so age may have some impact too. As you can see in the photo it's mounted (not screwed) ontop of a wooden structure which sets its height about half way up the tank. From what I can make of the installation instructions they recommend installing at the same height as the bottom of the tank? Assuming it's the fact that it's mounted on a spindly bit of wood, is it likely that changing this and/or adding a stone slab and rubber mat underneath it will reduce the noise at all? The guy in the youtube video seems to have it on a slab and a yellow rubber mat.
It seems to be fed from a t off the hot out of the top of the tank and a t off the cold inlet to the tank, again I don't think this complies with salamanders installation guides.
TIA
View media item 47350 [/img]
TIA
