Or RTFM.
I have never posted on this forum before
My "style" is of someone who doesn't rely on 'say so' and who likes to work on actual evidence and references
It is a shame that some people on this forum seem more concerned about their sensitivity to implied criticism (there was none intended) than about getting to the bottom of a problem.
I wonder why they bother to use a forum if they don't want to improve their knowledge and understanding of the subject. There have been a few useful bits of information for which I am grateful.
If the "talking" is just statements with no supporting evidence then, apart from a nice bit of social, what does it achieve?let the grown ups carry on talking.
What a crock of shyte.....I guess you're in the same mind set of those that use a thermometer for balancing radiators??Thanks for that.
0.4 vs 0.8K temperature influence is very interesting and surprising, if it really does mean what it seems to imply, then the air circulating near the sensor is dominating and that the conductivity of the case is very low.
Differential pressure influence is presumably due to the long length of tubing and the possible flexing with the fluid expansion in the bulb.The 20 minute response time is a bit slow and a wireless system should be a lot quicker than that. That 20 minutes is in addition to whatever the heating or cooling rates in the room might be.
Haha - the number scale instead of a temperature scale argument makes sense. In the light of people's great fussiness for their ideal temperature being within only a couple of degrees, that could explain how 'we' find crude number scales a bit unsatisfactory.
I must say that, in the absence of criticism of the wireless systems, I am attracted to having a wireless thermostat and being able to put it in an ideal spot. We have found a good place for the Hive thermostat in our present setup but that will need to be changed, no doubt.
Many thanks to the people who have made useful comments. Pity about the others (and their customers too.)
Elegantly put - as a reason for doing everything by eye and making do with second best.What a crock of shyte.....I guess you're in the same mind set of those that use a thermometer for balancing radiators??
Can always weed out the ones that do it for a living and the ones that don't.....![]()
There's not much point in continuing this but if you reckon that what you 'deem' worthwhile is the only stuff that's worth while learning then you have missed out on an awful lot of seriously important stuff.Hey Soppy , Ive been blessed with two mindsets.....a technical one when I deem it worthwhile...or in your case 'a useless couldn't give a fook one'.....
I've never heard so much useless drivel spouted in all my years..
