Improving router usefulness
probably a lot easier telling us what your ideas are or what job your trying to tackle
manufacturers have to make the tools as safe as possible so once a router is held away from normal [router cutter pointing towards ground]
they need to fully protect the cutter
so any manufacturer desighning equipment to allow the router to be used other than "normaly "must fully protect the cutter
mounting a router in a table is probably your best option
Thanks for your reply. Having bought a router and used it - precariously, on top of a ladder! - to cut a groove in the edge of a door, I wondered if there was any kit that permitted me to do this work more safely and more precisely. I checked out router tables but they do not overcome the twin problems of a narrow work surface at the end of a lengthy piece of wood that is difficult to secure. Cheers, BelmontR
clamp a bit off 2by2" to give you a larger area
if you arnt fully steady and feel in the slightest danger take the door off its hinges and work accross the top flat
i assume your putting in something like a fire strip!!!!!
I'm just wondering who hung that door so high, that a ladder is need to get to it? :shock: lol
Some would say that the non-lazy way would be to take the door off and prop it in a saw horse or workmate. :roll:
Buy a router table that is the safest option, make sure you use a half inch router in your table and half inch bits to avoid vibration.
