I have a DP cooker switch running to a cooker connection outlet via conduit 1m away under the worktop. This outlet currently has a 6mm cable running to an oven with a total rating of 2075W and a flexible cable running to a wall socket. The gas hob is plugged into this socket with a normal 13a plug.
I wondered if i could just connect an induction hob using the 6mm cable and use the redundant lead from the gas hob for the oven? If so, what sort of wattage would be OK for the hob?
The Cooker switch is on its own MCB cicuit from the consumer unit.
Thanks.
Thanks.
