Hi
Anyone help with this? I want to insert a tee into an existing pipe but there are branches off which make the pipe quite rigid.
Can you normally 'flex' the 15mm copper pipe enough to insert a tee after cutting out a small section?
Don't want to cut into the pipe then find out I can't insert the fitting!!!! That would be a ***** disaster.
