Just a quick one. If i change a DB and the client has also requested a PIR do i have to do both an installation for the DB change and PIR? I imagin i do. Can anyone advise? Thanks
I do a PIR in the majority of cases before I change a DB/CU anyways, not during or after. Then do the work, as requested based on the results of the PIR and issue the EIC.
