dont forget you cant pump mains water It has to be pumped from a header tank!i will be fitting a twin pump anyways to get the pressure up to the 2 bar recommendation.
reading on a bit,
Look what it says on page 15:--
What if anything electrical goes wrong?
The electrical system of these steam showers is simple, just three key parts, Steam Generator, transformer box and supply and the control panel inside the shower. Supply your copy of
the electrical installation invoice you were given when electrics were installed (cannot help you without this so keep t safe!) tell us what part you need on the claim form and it will be
sent by post to you.
Sounds a bit like, if you don't have proof (via an invoice from sparky) of correct installation, then you may have problems with a subsequent warranty claim.
reading on a bit,
This is almost certainly not enforceable. Its the same deal as car manufacturers trying not to honour warranties when non OEM parts have been used or work not carried out by the dealer. AFAIK there is plenty of case law that says whatever you did must have caused the 'problem'. Imagine, the plumbing bits go wrong and start leaking water and the manufacturer wants proof the electrics were installed by a qualified person? Pish!
All of that is unenforceable.Read again, the bit about a sparkies invoice was in the section 'what happens if the electrics go wrong?' , nothing to do with plumbing. There is also a disclaimer in regard to leaks
It might be clear, but it's irrelevant.You may be right, but i wouldn't want to be in a position of having to argue the case if i hadn't followed manufacturers instructions. They also have taken the trouble to inform the user of their legal position regarding the installation, this is clear.
The courts enforce English Law.who is 'enforcing' what?
Because consumer rights and contract law were being discussed.Im not sure why this word came into the conversation?
Consumer is not obliged to do this.Consider this:-
Electrical device fails,
supplier asks for evidence of correct installation to validate the warranty claim.
Consumer cannot do this.
That's a separate matter. Whether or not a building notice was issued has no bearing on whether or not there was a manufacturing fault.Supplier says 'it clearly states in the instructions...blah blah... claim refused.
consumer says:, ill take you to court then.
supplier, ok, but might i advise you that in doing so, it may well become apparent in a court of law, that you have broken building regulation laws in respect to elec. installs in special locations.
Then I suggest that you undig your heels and stop speculating.argue the toss if you wish, but personally i dont think its worth digging your heels in over speculation.
Is that not speculation?It seems that the consumer would have to take the supplier to court, if the consumer had not followed the manufacturer's instructions, i feel that they will be fighting a rather steep uphill battle.
Is that not speculation?Failure to follow the instructions IMO puts the supplier on the high ground
They are unreasonable - that's The Whole Point.Surely the simplest and best idea would be to comply with the instructions? They are clear in their requirement and are not unreasonable.
Sounds not a bit like, but entirely, exactly, solely and 100% like they know they have made a flaky product and are desperate to wriggle out of as many warranty claims as they can, even to the extent of using illegal terms and conditions.Sounds a bit like, if you don't have proof (via an invoice from sparky) of correct installation, then you may have problems with a subsequent warranty claim.
