I have a loft TV aerial and planning to connect four TVs to it. I have been recommended to install a TV amplifier near the aerial with inlet of aerial connected to an amplifier and four outlets to the TV in different rooms. Amplifier needs a power supply. I recently had house extended and have two electric cables running from the fuse box to the new extension. One is supplying power to lights and one to the new 4 off sockets (down and up stairs). Can I install a junction box in the loft in the wire that powers the new sockets and install a 2-gang socket? What size junction box I should use and fuse rating I should use? A circuit diagram would be beneficial.
