Insulating my ancient living room
My first job after the new sill was installed was to fit an outside tap and socket:
These outside sockets are amazingly badly designed. As reported by about a thousand screwfix reviews, the socket is off-centre because of the switch, but the waterproof flex outlet is central. No plug with any sort of strain relief has any chance of fitting. So why did I fit it? Well, SF have 4 brands for under about £10, all of which have the same issue. Then they have an MK one for £34.99 that also has this problem. There is an unswitched MK one for £24.99 that shouldn't have this problem, but people say its flap snaps off easily. Et cetera. So, since the extension lead that I use outside doesn't have a strain relief on its plug and does fit, I bought this one.
Inside:
The isolation switch and valve are going to be behind an access panel when it's finished. Note my favourite cable installation method, "cable-tied to a copper cold water pipe".
The other thing I've fitted to the wall before the insulation and plasterboard goes on is this:
It's a temperature and humidity monitor. The idea is to be able to plot pretty graphs of the conditions inside, outside, and in the wall; then maybe I can worry less about whether the insulation is making the walls damp etc. The modules communicate using RS485 (MODBUS) which I'm running over two-pair phone wire, with 5V DC power on the other pair. At 9600 baud this works fine over the sort of cable lengths you get inside buildings.
Looking good to me.
Don't think your project is going so slow, mine tend to take a decade+ from start to almost finished.
I too have thick stone walls (slightly thicker than yours) and insulating the living room and our bedroom are plans for the next time er indoors decides she wants to decorate them.
I also have a 6"+ thick stone floor downstairs, massive slabs with cellar space underneath so I have to insulate them in the cellar at some point - however going down the cellar is not so easy as it's been an 18 year dumping ground lol.
I like the sensor idea.
Keep up the good work and the photo's.
Insulation, plasterboard and radiator pipes fitted:
Panelling, using old floorboards, behind where the radiator will go:
Stained white and oiled, like the other one; grain is raised again, hmm:
And radiator fitted:
Soon I'll be able to get someone to fit the new boiler - that's the next major milestone.
Plasterboard all jointed, sanded and mist-coated, and window ledge made from the other half of the salvaged table fitted; and some more floor down:
I like the idea of reusing a table top.
I can't wait to see what you made out of the legs :)
I don’t have the legs.
I think that whoever dumped it managed to post the legs into the bin, but the top wouldn’t fit, so they left that leaning against the bin from where I acquired it.
The main job recently has been getting the new boiler fitted - see my posts in Plumbing about that, I won't repeat it here. But the boiler is now in the North West alcove of this room, with new plumbing under the floor to the two radiators.
Having got that done I could press on and finish the floor. It's mainly 75mm PIR; the pipes run in a 55mm channel with 20mm of PIR below. On top of that there's 18mm T&G OSB. The middle of the room was quick & easy, but the alcoves, windows and doors took me ages. But I did it without any serious mistakes!
The result is a room that is still half-full of building materials and has no finished surfaces, but is still better than the cupboard that we've been using as a living room for fractionally more than a year. So today I've moved the sofa back into this room:
What next? Well one major job is to connect the new boiler to the radiators in the rest of the house, which I'll not post about here. I'd like to get the other radiators functional before the winter. In this room, I need to tidy up the wall in the middle of the photo where I plan to make some built-in shelves, and then there's the wood panelling.
Oh, on the subject of the panelling, remember my white-stained wood behind the radiators? Unfortunately tiny gaps have opened up between the boards:
This may have happened when we turned the radiators on for the first time for testing, or it may have been earlier during the warm weather. It's not too conspicuous here but I would be less happy to have a whole wall of it. Any thoughts about that?
That's a double one, not a single.
The MK switched single may be less problematic than some of the other brands, but there are still reviews saying that being offset makes it impossible to use with some plugs.
