Ah, sorry, should have said - was thinking of taking a 'leg' off the radial with 2 smokes on it - it would save a fair amount of cable and work. The only problem I can see is fitting 3 rather than 2 cables into the terminals...
You're probably thinking of the rules for monitored ELV fire alarms SB where a spur would not be monitored so spuring is not allowed.
For mains ones the cables aren't monitored so it doesn't matter.
I've managed 4x 1.0mmsq into the Aico alarms - getting it all in the terminals was easy enough, but it was a little tight for wiring space with the cover on!
