Do any intermediate switches have built in terminals for the common wire, or do you always have to use a chocolate block?
Intermediate switching doesn't use a common conductor but two sets of strappers, so no.Do any intermediate switches have built in terminals for the common wire, or do you always have to use a chocolate block?
Never really done that way here. The conversion method of two-way switching is not the norm here.But very often there are 3 conductors between the switches with the conductor linking the two commons in the same triple and earth cable as the two strappers.
it seems all switches have a loop terminal
1) The OP is not where you are, he is in a different part of the UK.Never really done that way here. The conversion method of two-way switching is not the norm here.
Their PDF isn't detailed enough, this seller states that...
"Intermediate switches do not have the integral neutral loop terminal"
https://www.wentvaleelectricalltd.c...a-intermediate-wide-rocker-switch-15480-p.asp
Even though Hager's own website says that they do, I think they have just copied and pasted the specs from the normal switches.
I stated "not the norm". Obviously the conversion method could be used when converting from 1-way to 2-way - hence the name. (Although many might opt to rewire it with a traditional approach.)1) The OP is not where you are, he is in a different part of the UK. (sic)
2) What is done in your part of the UK (sic) if people want to turn 1-way switching into 2- or more way?
The norm is to have two sets of strappers. So here we would have two twin brown cables (for a T&E installation) into an intermediate switch and that would be it.The norm is though, for the two common wires to go in a connector block, I would say.
If anyone wanted to do a 'loop in at the switch' method, this COULD be done at the intermediate, so one could argue an intermediate switch could have TWO loop terminals.
But that would be silly.
