Internet Explorer Help.
28 May 2007
Surrey
Just wanted some advice on a curious problem I keep when using internet explorer.
I usually have between 10 and 15 windows running simultaneously and when I close down I get a message telling that the instruction at 01x xxxx xxxx etc could not be executed. Any one got any idea what this refers to ? Sometimes it will also completely lock up or just crash for no reason. Don't think it's a virus and I am running over a gig of ram and the commit charge is very low. Any ideas reatly received.
It would be useful to have the whole message. Check the event viewer for errors that occurred at the time of the crash. Some will provide links to information which may (mostly not) provide a solution. You can always post the errors here.
Guys checked the event viewer didn't seem to give much info got an error report message that usually gets sent to microsoft but it wouldn't let me copy the contents to post them. Any ideas how else to get the details this is getting very annoying now !
press print screen, go into piaint, press paste save a picture and post picture.
either that or type it out
or as its you connect it to a galaxy and text it :LOL:
no, you really can do it.
see, here is a pic of this topic
Here is the error message when explorer decided to die does this mean anything to anyone ?
[/img]
Ok, we'll need some more info about your system. provide as much detail as possible:
Make/model and board type if possible.
O/S and service pack details.
Memory capacity and type.
A/V software.
Cards installed.
IE version.
The error code generated refers to a memory access violation, which can be caused by a bad memory cell or a bad driver. Norton A/V can also contribute to the error, although a fix was released.
Are you running the latest drivers for all your devices (i.e. have you been to the various websites and installed them, rather than using the supplied disks).
pentium 4 2.53 ghz ,motherboard : Gigabyte Ga8pe667
Windows XP 2002 SP2
1 gig of ram PCI 2100 ddr 512x 2
A/V AVG Free
Nvidia GFORCE FX5200 on pci, USB X2 on PCI, NIC on PCI
I Explorer version
7.06
Hope this makes things clearer thanks again for your help
A defective driver generally wouldn't cause an isolated access violation within an application. More likely the application is corrupt or the plug-in's are corrupt. A faulty memory stick is possible, but it wouldn't just affect one application.
Ok should the app be corrupt how would I rectify this re install i explore again I guess ?
Try re-installing / repatching, no guarantees unfortunately.
The OP said that he had 10-15 windows running, so it's difficult to determine if it is isolated or even if IE is at fault. A badly written driver, or indeed application, can easily attempt to access a portion of memory, which has been reserved, causing a perfectly operational application to abend.
Um. no it can't
