IPx4
27 Mar 2008
Ipswich
Trying to choose a light to go above my shower enclosure
Going by an online diagram, above a shower enclosure is zone 2 , which states the light needs to be IPx4 upwards
Now, i'm trying to find a light but can only find bathroom lights that are either IP44 or IP21
Does IPx4 = IP44 and IPx2 = IPx21 ?
So would I be right in saying a light with a IP44 rating is suitable for a zone 2 above a shower enclosure?
Hope someone can make sense of that :oops:
IP44 meets the IPx4 requirement; the x is a wildcard signifying that there is no specific requirement for that number. :)
The first number is protection against ingress of solid objects, and the later, that of water (but if you protect against water, then you generally offer some protection against objects, so ratings such as IP04 don't exist in the real world!)
I assume your ceiling is at least 2.25m high?
I'm a bit confused about the zones thing ...
Will IP44 lights be OK for above my shower tray? Zone 1?
Why do people advertise IPX5 lights - surley they are still good for Zone 1 but good enough for Zone 0 ... so no better than IPx4?
:confused:
The IP rating system is designed to cover a whole range of electrical fittings, not just light fittings. The fittings may be for dometic, commercial or industrial applications.
There are applications for IPx5 light fittings. They may be appropriate for, say, a light fitting in a porch. it isn't necessarily anything to do with lighting in domestic bathrooms.
It is possible that the protection against objects is higher than protection against liquid. A box with ventilation grills under an "umbrella" fixed to the box can be IP32 to prevent fingers, nails etc being pushed into the box that may be rained upon.
http://www.protectingpeople.co.uk/fire_tech/ip_explained.htm
Thanks banm-all-sheds (BTW: what have you got againts sheds?)
Sorry typo re . IPX5's
Should have read
surley they are still good for Zone 1 but not good enough for Zone 0
Its all a lot clearer now .... ordering my IP44's today!!
PS: Does anyone do a mains extractor shower fan that is IPx4?
My electrician told me I must get a 12v one?
I mean this:
not this:
Which zone is it going in?
